Hi.
I recently bought the 5HP Briggs and out of the box it's having problems.
It seems to start and idle fine when in neutral. But when I shift gears it sputters, backfires, and dies when I barely crank the throttle up. I am testing it on a stand out of water so I'm not sure if there's anything with that.
Even when I try to throttle up in neutral it will sputter and convulse badly, backfires (backfires more frequently the more I try to nudge up the throttle), and then eventually dies.
I figured that perhaps the motor had been sitting up for a while and possibly collected condensation so I let it run to warm up for about 10 minutes. Came back and tried to throttle up a hair and it just repeated the above symptoms.
I read somewhere that a while ago they possibly had defective speed limiters and simply disconnecting it allowed the motor to run normally.
I don't want to just disconnect it randomly at this point. I was wondering if anyone has heard of this and if there's anything else I should be looking at?
Thanks.
Also want to add it won't shift into reverse.
Thanks.
