Re: 59 evinrude power problem
Hello.<br />Try replacing your spark plugs and dump a can of seafoam in your fuel and run it.Check to see if your contacts are still in good shape and at o.020 inch.<br />If none of the above works you may have to take your carb apart and clean it.<br />Good luck.
