Ok so we originally thought that it was a spark problem but we ruled that out, strong spark, then after trying to get it started I noticed there was some fuel under the carbs in one of the pockets on the bracket. We did a compression check with the top cyl at 120 and the bottom 2 at 122.
It is possible that the fuel under the carbs was us squeezing the bulb to many times when we where trying to start it and the fuel ran out the carbs, or there is a leak or malfunction on one of the carbs My plan is to get the kits for both the carbs and the fuel pump and rebuild the fuel system. But what I would like to know from you guys is there something I might be missing that I need to check before starting this process?
