michaelj1978
- Jul 8, 2004
- 50
Well I finally had the dealer put on a new tach as some of you said the 19pitch prop would be too much for my 50hp evinrude (1995). <br /><br />Took it out this weekend with 10 gallons of gas, 400lbs of people and probably 200lbs of gear. Boat is an 18ft flat bottom jon with a fully finished interior.<br /><br />The old tach was reading over 7,000rpm no matter how it was adjusted on the back. The dealer hooked up the new one and wide open throttle was giving us 6,000rpm with the motor tilted up a few inches. With the motor fully down in the water pushing the front end down we were right at 5,000rpm. At 6,000 when the front end wasn't pushing, we were running around 29mph. <br /><br />I know some on here had said before that that prop wouldn't push my boat, but appearently it does, and does pretty well. <br /><br />I'm even tempted to raise the motor one hole and see if that can help get the front end of the boat out of the water more and see if that changes anything. If nothing else I can drop it back, but I'm pretty happy with how it ran compared to how it used to run with the 15pitch prop. The 15 used to get us to about 20-21mph then start to ventilate and overspin. The 19 doesn't do that unless you intentionally raise the motor up too much.
