50 HP Carb
cody7914
I have a 1986 50 HP Force and would like to change the needle and seat. Before I start I think I could use some expert advice on how to remove the pressed in seat. Thanks for your help.
Frank Acampora
Re: 50 HP Carb
Why do you want to change the seat? unless you have a specific problem--fuel overflow due to damaged seat, changing it is not warranted. Before you go through the cost and fuss, double check to see that some crap is not wedged in the opening. Remove the inlet fitting and clean the inlet passage thoroughly.
However, if you absolutely must change it: There is no way to remove a pressed in seat without damaging it and it will not be reuseable. Take an appropriately sized lag screw and thread it into the seat. Then using a Dykes wire cutting pliers and a bar of something to protect the carb casting, grab the screw by the head and wedge out the seat.
jerryjerry05
Re: 50 HP Carb
Lots of people rebuild the carb.Lots of people are wasting their money.
Most times they just need to use a carb cleaner.
Also an inline clear filter is a good thing to install.J
