sw33ttooth
- Apr 24, 2011
- 498
1991 four winns 225 sundowner 351 ford
read post #5 new issue
ok a tottaly new issue at hand now i havn't replaced spark plugs yet tomarrow i get plug wires i will do them then, as for now boat fires up and will idle around .5 rpm i can put it in gear and it will start to putt, but once i tap it down a little further to lets say 1 rpm is sputters for about..... 15 seconds and then kicks up to 1 rpm once i am over 1 rpm i have no problems i drop the throttle and it speeds up or i can take off slowly. so i am pretty sure its not the carb. and i just replaced points and dist. cap i will post my findings after i put the new plugs and wires in tomarrow hopefully fixing the problem.
NO NO NO not at the lake.. The dang thing might not shift outta gear.. What a mess that would be.. I thought you was playing in the driveway... Fed up?? It's a boat..ment 500- 1000 rpm ....... starting to get fed up with this boat but i know there is gota be only one more issue i will check ESA next time i go out thank you.
