Ayuh,.... I ain't seen a steel shim head gasket in an Oem motor since the '80s,....
I've never seen a steel shim head gasket used in a reman motor,....
The only steel in a composite gasket is the fire-ring, 'n if water gets that far, you've got other bigger problems,.....
