mike96chap
- Apr 29, 2015
- 22
Hi all. My name is Mike and I'm having some issues with my motor. The rig is a 1996 chaperral 2135ss. It has a 5.7 with a thunderbolt v ignition. I picked the boat up with no spark. Today I ran all the proper tests And ended up with the following. Replaced the pick up sensor in the distributer As well as the coil. Checked for 12v at coil + and have 12v. Checked for 12v at red white wire And have 12v. Grounded coil lead and tapped white/green wire to ground and no sparks. This leads to the ignition Module. My question is. Is there any other ways to verify the module is bad other then these tests? The only thing I haven't checked is the key switch. The guy I got It from replaced it prior to me purchasing it. Second question is. If the module is bad. Being I can't find any used ones anywhere and the dealer wants 620 for the new part is it better to just go with the gm Delco voyager set up and redo the entire ignition. I'd really like to get this thing running. I purchased it for 2800 in mint condition other then the spark issue. Thank you in advance for all the help.
