sickandtired
- Aug 24, 2013
- 8
My old Merc 4hp 1990 started to exhaust gas (gas in the lake). There are no leaks anywhere. The local mechanic said it was a normal operation. Does anyone have an idea of the source of the problem?
Hi Mark and thank you for responding. The motor doesn't smoke, but there is a wide film in the water in neutral. I never troll. I operate at 50 to one oil mix. What does WOT mean and what do you mean by run strong?
Bert
WOT was answered. Run strong means that when you give her the throttle she takes it and moves on; no balking, hiccuping or any of that like weimed mentioned.
On leaning out the carb, if you decide to fool with the low speed jet, if you get it too far in...too lean, the engine won't run strong and you can have piston scuffing problems.
Mark
Yup, and fuel pump kit too.What do I need to rebuild the carb? Carburator kit?
