Have a 2007 Mercruiser TKS engine. Took boat out friday. no issue. Took boat out saturtday, no issue.
Yesterday took the boat out and got a quick "Beep".. "Beep". Water Temp 165-170, good oil pressure, and lower drive fluid right at the "add line".
Thinking it has to be the drive fluid. Get some at marina and fill up right to the "A" on the "Add line". Boat ran fine rest of the day, no alarms.
Go out this morning, no alarms. Coming back this evening, started beeping on and off again. Seemed to stop when boat slowed down, started beeping again when speed up. Again, water temp good, oil pressure good. Lower unti fluid at same level as yesterday where i filled it up too.
Is there anything besides oil pressure, temp pressure, and gear oil monitor that will make mercruiser 4.3 tks beep?
Appreciate any help i can get.
