wglanville
- May 13, 2010
- 59
I currently have a 74 25hp short shaft, and I have the opportunity to buy a 78 35hp long shaft, (which I need). I can get it for $300 because current owner says it needs new rings. Compression numbers are 130 on upper and 122 on lower... Pretty good numbers right?. Could rings be bad with those compression numbers?. His reasoning is lack of power. He said it takes a long time to get up on plane on his 15' aluminum boat.
Spun prop maybe?. What else would cause loads of power like that?. What would it cost approximately, if I needed new rings?
This site has helped a lot in the past, hopefully it comes through again, thanks I advance for the advise.
