Well, I went out to check out a New Prop today. The wife took off Tomorrow, for my Birthday, and Monday for some boat ridding. Oh guess what. I ran the boat today and ran about 15 gallons of gas through it. Docked to refuel. Filled the tank. Started Engine, and backed out. Put into Forward, and had a Vibration. Killed Engine and found a Stick in the Prop, lodged next to the Prop Nut. Pulled the Stick out! Started Engine and it had a terrible Miss. The only hose I found loose, looks like a wire loom hose, which goes to the PCV valve looking thing on the Port side Valve Cover. I looked all up under the Air Cleaner could not see where it hooks up! Anyway, I would not think this would make the boat run this bad. Could not get it above 3000 RPM's Ran all the way back to the dock. After docking and backing the truck into load, the boat would not start. Took a long time for it to finally start and it had no power! <br /><br />Is there any quick things I could check out, that may have come unplugged or something. The Wife is dissapointed that she took off work for nothing. I also took off work this weekend. This has to be something simple. It sounds like it is not getting enough fuel, or Air Mixture!<br /><br />This is a 5.7 350 MAG MPI, 2003 model. <br /><br />I would appreciate any suggestions, please be discriptive, I am not a good Mechanic! Thanks for any help in ADVANCE!<br /><br />GodsBeast
