Re: water pump and flushing device/ear muffs
Maybe it wasn't submerged. I hope i'm not that stupid...I thought it was way past the pump, but i'll check it again.
I bought a pump kit which had an impeller, new plastic housing , gaskets, and metal cup. I smeared a little gear oil in the cup, and rotated the shaft until the pump housing slid over the impeller. I also used gasket sealer on both gaskets. One possibility is the plastic key that holds the impeller in place. The kit didn't come with one so I made one out of hard plastic. It worked fine, but maybe it came out some how...I'll check it out tonight....
Paul said:The water pump was submerged was it?
What did you do precisely when you serviced the water pump? Has it got a plastic housing and was it replaced?
