Chuckyd973
- Apr 7, 2010
- 34
Re: 3.0 OMC ignition problem
What is your timing set at? I have an 04' 3.0 HO motor with points and im 8 degrees ATDC. Also verify compression. I had a blown head gasket that was sperated under the intake/exhaust manifold. It was blown on the exhaust side of the head only so it confused the hell out of me that it wasnt just an exhaust leak. Also have you done any manifold gaskets lately? The wrong gasket can cause fuel to pool in the intake. One more thing. While its running try removing the PCV valve hose away from the carb. See if that makes it run better.
CHUCK
CHUCK
