LakeTravisAlpha1
- Mar 15, 2016
- 33
I tried to start my '95 Mercruiser 3.0 LX Alpha One #F452165 today. It hasn't been started in eight years but did run on the trailer the last time I tried it. A few days ago I changed the oil which was surprisingly clean, pulled the plugs which too were clean and in good shape, sprayed the carb with cleaner, installed a new battery, put fresh gas in along with a can of Sea Foam and this afternoon changed the drive oil.
The carb was / is dry as I posted in a previous post so today I primed it with both gas and carb cleaner. It would turn over but other than that, made no sign of it wanting to fire off, no sputtering, no death rattle. I noticed none of my gauges now work either. There is a red fuse button on the engine that appears to be stuck in the out position as I can't reset it but am not sure it even does push back in.
I've read the long list of possibilities that could be wrong, everything from a bad tach connection to ignition switch but I don't have a clue where to look first. The Tilt / Trim works now as well as the Bilge pump, albeit it now sounds like an air horn, but the fact that all of the gauges are dead makes me think it's not getting a spark.
I have a mechanic buddy that said he would try and make it out and have a look and I'd like to at least contribute something other than "it won't start." What would be the first places to start looking? It started and ran the last time I tried it years ago so I can't imagine it being out of timing from just sitting.
