We use those 2 strokes 25-30 OB's for hours use to tow surfers on a daily basis, have OB's with more than 1K continue metered worked hours and not a single impeller nor fuel pump failure. If you remove a original impeller off housing, will see how blades springs back to original shape, that tells much of the quality they are made of, no other brand will be capable of returning to its original shape once removed.
Will recommend to run carb dry of fuel after outing, while flushing OB remove OB fuel connector and let OB die of fuel starvation, carb will be kept cleaner. Being a second hand OB, could remove carb silencer (black protruding part) and while flushing ON with muffs, or on a barrel squirt shots of power tuner to decarbon cylinders, piston, piston rings, follow can intructions. OB will run as a champ..
Happy Boating
