Hello to all,
first alittle history on the motor
I have a 2005 merc 25/20 jet. The motor came as a manual start and I had it rigged for remote controls/electric start from the dealer. Everything was fine for the first year and a half. Then I had a start solenoid go bad. Dealer replaced it and 2 weeks later, it started acting up again,dealer replaced again free of charge. 2008, starter goes bad and I take it to a different OB tech (I had little faith in original dealer by now). Replaces starter and goes over all wiring. First trip out starter starts acting up and it tests out as a bad starter. Replaced again. Late last season I had to replace starter and solenoid again. While I was at it I replace d batt., batt. cables and a few other wires for the system. Thurs of last week I have the boat out, starts fine all day, back the trailer in the water, go to drive on the trailer, nothing but a clicking solenoid. Try to jump the solenoid, NADA.
So I went over the simple stuff this weekend, battery, batt. cables fuses, and replaced the solenoid w/ a new one I had as a backup. The wiring harness from the controls is good , I've been using a short keyed harness at the motor to test everthing. Tested it per the merc manual and it's coming up as a bad starter. I did find a small spot on the harness in the motor w/ what looked like a melted spot, there was elec. tape over it and I didn't notice it till now. looks like this could be it and I'm ordering another one.
BUT
any other things I should be checking here. I'm no mech., obviously. Would a bad rectifier cause some of these ongoing probs? Battery stays charged though.
thanks in advance
Matt
BUT
thanks in advance
Matt
