johnspruill
- Mar 19, 2016
- 15
Over Heating problem with 228 Mercruiser, 1982 year, 305 GM V-8, serial no. 6045972. I first noticed I had a problem when I blew a hole in the Port baffle that comes out of the elbow riser that is attached to the log style manifold. I had my repair guy, who normally works on the boat, replace the baffle. He had a used baffle, but it appeared to be in good shape. Everything worked fine as far as I could tell until after maybe 10 hrs use, it blew another hole in that replaced baffle.
I questioned maybe the used baffle was bad, but that didn't seem likely, so we started to look for heat related problems. I've got a laser temp gun and started to check the temp at different locations. The starboard side of the engine including the manifold, elbow, baffle, hoses never gets above about 120-140 degrees. But the port side temps are all over the place. Some times it will start out acting normal and run for 10 minutes fine, then start to heat up to over 200+ degrees. Other times it will start heating right away, and then may start to cool back down to the 120-140 range after running a few more minutes.
At first we thought I had a plugged manifold, elbow, or even a bad shutter value, but now I'm thinking it could be something like a bad thermostat or something that is opening and closing the PORT SIDE ONLY. Have NOT replaced the thermostat yet, but wouldn't think it would be selective (port or starboard)? I have also heard that some cooling systems that use a check ball and spring setup that controls the water flow. Not sure if that would apply in my case? But this sounds like it could be more selective and might be my problem??
We have replaced the impeller in the out drive recently, and the system appears to be getting water or both sides would overheat I would think. The starboard side log manifold was replaced 4 years ago because it was cracked. The engine itself does NOT appear to be over heating, just the exhaust manifold, elbow and baffle at times. Engine appears to be running okay also.
Any ideas whats going on, and how to trouble shoot? And how about the check ball & spring question? Where would that be located? Thanks much. john
