fisherman1818
- May 27, 2016
- 5
Anyone else have these problems?
I purchased a 2016 Crestliner Discovery April 2016. After the first 30 minutes of use I had to run the bilge pump for several minutes. I did use the livewell. I went to the dealer when they were repairing it and someone at the factory had drilled a pilot hole through the livewell fill tube. The livewell overflow also would not drain. The dealer found that the overflow drain tube was pinched in 1/2. Also found were pre-drilled pilot holes for rivets without the rivets. The in-deck rod storage lock did not work, the dealer had to cut the slot with a saw to make the lock work. The prop on the Mercury Outboard had about 3/8" of play on the shaft. Has anyone else had any of these problems or did I just pick the wrong color boat that day?
