Re: 2010 50 tohatsu tiller handle
A TLDI tach is more than a 1-wire connection. The 3 indicator lamps are in the harness also. Assuming you have a TLDI tach, you should also get the Factory harness to connect it. Following along with your Factory service manual, the the harness is plug-and-play.
