shackle101
- Jan 11, 2012
- 140
Hey guys so I'm having issues with my 4.3 mercruiser starting, and running smooth when adjusted into low RPM. Once you do get it started it will run fine at high RPMs, but if you go down on the throttle it will turn the engine off.
I know there was some old gas in it I ran on so I replaced the Fuel filter with a brand new one. Now it's having issues even starting. When I filled the fuel filter up it started and ran fine for awhile, but had issues again after a few mins. I checked all the fuses and nothing is busted. The fuel pump seems to be running fine, and the hoses going into the filter seem to have gas in them when I unplug them.
Any ideas here?
Thanks!
Any ideas here?
Thanks!
