2007 30 HP mercury compression?
jayman02
I saw a 2007 30 hp mercury 4-stroke outboard for sale, in the description it says all 3 cylinders compression read 70 psi. I contacted the seller and they told me that there is no spec PSI range listed by them manufacturer, only that the cylinders be within 15 % of each other. I have searched everywhere for more information but I cannot determine if this is an acceptable compression. Does 70 PSI on all 3 cylinders indicate a good running outboard? I appreciate any insight. Thanks.
Faztbullet
Re: 2007 30 HP mercury compression?
From the Service manual:
COMPRESSION RATIO:
Compression Ratio 9.7:1
Cylinder Compression*
(Electric Models Only, Cold Engine @ W.O.T.) 180 - 210 psi (Peak)
His gauge must be way off or it wasn't tested....
CharlieB
Different quality of gauges will often vary greatly.
If you are seriously thinking of buying the motor buy or borrow a decent guage from NAPA or AutoZone and test the motor yourself, also test to ensure a hot blue spark of at least 7/16 inch, and most importantly, take to boat/motor out for a ride on the water so you can KNOW that it performs well. Running on the hose, or buying a motor based on compression alone is no warranty that the ignition or fuel system work.
