seventeen2
- Oct 9, 2009
- 64
Good afternoon all,
I have had an ongoing problem with my engine regarding tickover and stalling.
I thought it may have been water in the fuel, so had the tank emptied and cleaned out.
The engines ran fine after this, but i then discovered that my tickover was too high on one engine, roughly about 950rpm (out of gear), although the tacho says it running at 500rpm?
I tested the actual tickover with a lazer gun on the crank pully.
When i tried to adjust down the tickover to roughly 700rpm i find the engine will start to shake and die off, and when i get close to 700rpm, when i try to put it in gear it will stall?
I remember seeing a procedure of setting the idle speed up, using the idle mixture screws, but im unsure to touch these as i dont want to wreck the factory settings and it seems these screws are covered by a tamper proof cover?
Please could someone give me a few pointers as its one of those issues thats really starting to get on my nerves!!
Kind Regards
Dan
Kind Regards
Dan
