2005 TL-60 TLRD fuel injected will not idle below 1,000 RPM
johnnyClack
Helping my Co-working TS his boat engine ....:redface:
Engine sat two years, before attempting to start:
? Old fuel w/Stabile was drained, new gas placed in tank
? New fuel filter was changed out
? Old spark plugs removed, engine was spun until fresh gas smell showed up
Engine was started up, test ran with muffs:
? ? RPM?s appears to run OK
? Would not idle below 1,500 RPM?s before beginning to run rough= start popping= die
? Injectors were removed, taken to local NAPA dealer and tested, appeared to pass/atomize fuel OK, did not have GPM flow rate to verify rate
? Engine will now idle down between 1,100 to 1,000 RPM?s before beginning to run rough= start popping= die
Electric fuel was replaced and ran before storage without any apparent problems. Replacement pump was a Ford MoCo, specified for a Ford Toris SHO
johnnyClack
Re: 2005 TL-60 TLRD fuel injected will not idle below 1,000 RPM
Well, where are all the Yammy Tec’s ?
99yam40
I am not a Yamaha tech, but putting parts other than the ones listed for the motor will probably not get much response.
But checking pressures would be a start
johnnyClack
Yes & I couldn’t agree more> Believe me I chew *** for this stupid move, it’s usually driven by cost savings which seems to always comes back to bite in you in the END (pun intended)
Where are the fuel test points on this motor
99yam40
Not real sure, but should be on rail for the high pressure to injectors.
Service manual would be a great help
johnnyClack
Looking for a Factory Service Manual for this motor
Any suggestions ??
johnnyClack
Thanks for all your help fellows……. Spark plug wires were crossed up
