Re: 2005 Reinell 191 LSE - Gauges not working
Checking the positive and negative on the Fuse Panel:
Key off - 12.75
Accessory - 10.00-11.50
Run position - 7.50 (what?)
If your voltage at the battery is staying at 12.75v, then you have a problem with your connections. likely loose or dirty.
There is this really annoying alarm that is red and has a positive feed and negative feed on it. Well I thought I would disconnect it because I was getting annoyed, specially in the run postion.
I hooked that negative lead to the negative clip on my meter and checked the postive lead on the fuse panel:
Key off - 12.60
Accessory - 12.60
Run position - 12.50
I hooked that negative lead up to the fuse panel and everything works. I tried chasing the normal negative cable back to the engine compartment but get lost considering I can't see because everything is so tight. Any idea where the negative cable should go?
That is probably your alarm, and if it is like my unit (which they may have changed design from 89 to 05
) it is not normally grounded, normally when one of the sensors fail, they short to ground and the positive goes through the alarm and makes the really annoying sound. I would suggest:
1. find what sensor is shorted to ground. if you have not been running your engine, it is likely the Oil Pressure sensor, which is always grounded when the motor is not running. Other sensors: Temp Sensor (overheat), Trim sensor.
2. Fix your original ground, and re-connect it to your fuse box. You can run a brand new ground if needed, but it is best to find and fix the original ground. Notice the different voltages with a good ground and bad ground. you may want to check the boat to engine connection, sometimes they get a little flakey. If you do not replace your original ground, nothing will work when your motor is running properly.
3. If your "run position" was with the motor running, you also have a problem with your charging system. If it was without the motor running, that is fine.
There is this device that the positive lead goes to and has a Red 50 button on it. What the heck is that?
The thing with the red button is a circuit breaker.
