Just rebuilt the carbs on my 90 hp 2 stroke mercury. Wouldn't idle before and now it idles great but a little high. My question is about the sequence of adjustments as the factory service manual is a little vague. I have the carb adjustment needles all 1-1/2 turns out from slightly seated. This gets it firing right up and runs great, but with it idling around 1800 rpms it'll slam into gear when shifting. I can turn in the low mixture speed screw and get the idle down to 1000 rpm's but it'll cause the motor to die when put into gear. I know there is a timing advance/retard adjustment "idle" screw as well. My question is, do I leave the idle adjustment screw completely bottomed out until I adjust the carbs, then once I get the carbs adjusted using the idle adjustment screw to slow the idle down?
I am adjusting the low mixture screw on the carbs with the boat tied to the dock and in forward gear
