2005 15hp Johnson won't reverse
dkavanagh
Recently serviced, and worked fine for a few weeks. Just started acting weird in the middle of a recent outing.
- "Reverse" shifter position is now neutral
- "Neutral" and "Forward" positions are both forward
- Can only pull start in the "Neutral" position, which means it's in forward gear when I start it
Any advice helpful.
Model # required.------2 stroke or 4 stroke ?--------If water pump was serviced on a 2 stroke you may need to check shift connecter assembly work.
dkavanagh
Thanks for the responses. It's a 4 stroke, model R4.
The service was a standard tuneup. There were no significant problems I'm aware of before the service.
jakedaawg
The shift linkage may have become unfastened. There is a 10mm barrel nut and a 10mm jam nut. May be 12mm can't remember. Anyways, it's on the front of the lower in the opening under the swivel tube. Check to make sure it's still fastened.
