2004 Yamaha outboard 115 HP 4 stroke
KLSS
I Need a little help please, 115 4 stroke will ONLY idle, its been sitting over a year. This is what i have done. hooked up to laptop it showed pulse coli, temp sensor, tps sensor. I cleared codes and started engine ran it over 30 min at idle. all active test showed normal.
Please help, thanks KLSS.
99yam40
not much to go on.
Might monitor fuel pressures to make sure they do not drop off
KLSS
Thanks 99yam40. I will try that. what should the fuel pressure be?
Thanks, KLSS.
