bobtylerjr
- Dec 28, 2015
- 36
Starting problem on 2004 5.0 Gxi and hoping there is someone who will be able to help.
I have a 2004 Sunesta 236, recently purchased used. Ran fine for about ten hours,without issue. Would not start on last attempt to go boating. I had both batteries tested and replaced with new 1000 CCA Interstates. I have bypassed the kill switch behind the cockpit panel (temporary to isolate the problem). I located and checked one 50 amp circuit breaker (located on back, stern side, of engine). The breaker did not feel "popped" when I checked it. I checked all fuses in the fuse and relay box on the top of the engine. I checked all circuit breakers behind dash, although none appear to even be potentially related. No breakers behind the dash were "popped". The boat has ample fuel. The fuel pumps make a noise as if they are running normally when I turn the ignition key to the first detent. I consistently get the alarm sound when I rotate the key to the first detent as well.
I am at a loss except to start replacing parts, call a mobile repair or take the boat to a dealer. I am reasonably capable of swapping parts and mechanical work but I am out of ideas in terms of further diagnosing the problem. Any help would be greatly appreciated.
Thank you!
Thank you!
