Was out on the lake this weekend and had gone about 30 minutes when I got a beep followed by another beep. Didnt see any warning messages or anything show up on the screen. went thru the display and all looked fine , good water temp, good oil pressuure , good everything. Then as i continued on it double beeped again. So I throttled back to idle and the engine quit and DATA BUS Failure came up on the display. Waited a while and cranked it up and it started so I turned around and headed back to dock. before i put the boat on the trailer I slowed up prior to the shore to see how slow in RPM it would go before cutting out. I got to 1000 rpm and then it quit. SO i waited a little while and tried cranking it but it wouldnt catch. So while i was cranking I slipped it into forward and it started. Thankfully as I still had to get back to the dock and onto the trailer. So what is this Data Bus nad what could be the problem. To me it seems like it would be a throtttle position sensor or something that went bad or has the computer crapped out ? Anyone have an idea ? I know if I call the dealer their answer is bring it in. But if its something as simple as a throttle sensor that I can replace then i dont see spending the money to haul it all the way in to have them change it out when I can do that. So If someone has an idea i'd appreciate it. Thanks.
