No water coming out of drain hole in neutral.Flows fine when moving.replaced impeller and cleaned hole.running hot.
Hi I'm wondering if you solved your issue. I have an 03 60 hp that is not peeing well at all. new water pump and gasket last year. I checked the line to the tell tale and its clear. Curious if some sand is lodged in the engine somewhere or at the intake. Thanks and happy boating!
