2002 Mercury 140hp Outboard Rebuilt Hot with 23psi
chapin123
HI, i have a problem with my motor and it is that when cold the water pressure is at 10psi , but when we run it at 3500RPM it gets hot and the water pressure goes up to 23psi.
We suspect that there is a leak somewhere. All thermostat and puppet valve have been replaced.
Please send your comments.
Dukedog
Tha very first thing you replace on an "unknown" heat problem (after actual over heat is verified, not sensor or module) is complete OEM water pump kit....... Then go from there..........jmo
