Hi, I ran my boat ('88 GW Tournament 19) out of gas last weekend trying to get to the only gas dock around and have since had problems with fuel delivery. I tried changing the fuel/water seperating filter thinking maybe it was clogged but no luck. Basically what is happening is that if I prime my bulb good the motor will run for a couple minutes at cruising speed and then bog down and die. When I check the bulb again after the motor has died it is completely deflated and very difficult to work fuel back into it. Could this mean that I have a blockage in the line somewhere or could it be the fuel pump? It seems to me that if the bulb is being sucked down flat then the pump is pulling a good amount of fuel but there is a blockage somewhere. I've heard of there being a small screen in the fuel line just after the tank. Is it possible that I clogged the screen when I ran the tank dry? The first time I changed fuel/water filter there was a fair bit of junk in there. Any thoughts help. Thanks.
