CableGuy1978
- Jul 13, 2010
- 66
Hello,
Had a fuel leak a couple of weeks ago from the schrader valve on the fuel return line. I have a replacement return fuel rail. Just looking for tips on how to remove the old one.
Is there a trick to removing the lines from the fuel injectors? They look as though they just pull out but I don’t want to force them
Is there a trick for the mainline with the red connectors, they look as though you push the red part in the uncouple them.
After the new rail is installed is there anything I should know before starting it up?
Thanks very much!
Thanks very much!
