After about 15 minutes of running at 10-20 mph I slowed down to dock . I raised the drive slightly because of 2' water. After 40 seconds of idle speed the oil alarm sounded. I shut down the engine and removed the cowl. The oil level was fine. The engine was running fine prior to the alarm. This happen 3 times under similar circumstances.
Oil is fresh this year and look clean, engine runs fines otherwise.
thanks
thanks
