I have a 2000 Larson with the volvo penta 5.7L engine, duo prop. I have always had a 40 mph top end until recently. The boat is running at 4000 RPMS at full throttle as always, but I am only getting a 30 mph top end speed. It sounds like its hesitating at full throttle as well. If I back it off a touch it will smooth out and I actually gain a mph or 2.
Is it safe to assume my carb is getting gummed up? I have run 85 hours this season on ethanol fuel. I cleaned the tank out and replaced the filter prior to this season and the addition of ethanol.
The boat runs great otherwise- should I pull the carb and clean/inspect?
Thanks for any input.
The bottom is clean by the way- spotless actually.
