Stingray190LS
- Sep 28, 2015
- 10
Having lots of trouble with my engine recently... Main reason why I replaced lifters is because of the noise - pls see video. Anyone familiar with this? If so what did you do to resolve?
I'm having trouble adjusting the valves correctly and will try again (this time maybe adjust while running - will this resolve a valve stuck open if adjusted while running and tell the difference since engine will run better?!?)... If you notice, only at 20psi and would the engine shaking be related to that since still not idling properly?
