I have a 200hp Johnson outboard. the motor will not turn over. The motor was left sitting for 2 months and the tilt motor seized up. I tried to tilt the motor up, she only went about an inch then stopped. The tilt motor was seized and I think it caused something to burn out. I tested the old tilt motor and it would not turn, so i replaced it with a new one. Now the engine itself will not turn over, and there is still no power to the tilt motor. I made sure the batteries where fully charged, and I tested to see if there was power to the solenoid, you can turn the motor over by crossing the solenoid. There is no power going to the key, the instrument panel does not light up. Is there a fuse somewhere on the motor that may have burned out? or could it be something else? a wire burned off maybe
