I was running my boat around 4500 RPM .All sudden I lost lost power down to 300 to 400 rpm then stalled. Seem like the motor was starving for gas. Check the primer bulb and it was soft.
Start the motor up again and wasn't able to go pass 2000rpm . Limp to the fishing place.
Fishing for a few hour. Started the motor up and everything was fine again. Also a buddy of my
pour a whole bottle of startron fuel in the tank after pump only 10 gal of gas. Could that cause my motor bog down? After spending hours googleing the ox66 bogging down. I decide to change vst filter 2 lower pressure fuel pump , send the injector for cleaning, replace fuel and water separator. Is there anything else could cause it bog down or lost rpm. Any info will be helpful.
Thanks
Thanks
