1994 Mercury 200HP carbed OG166xxx serial number, starts hard once warmed up. Starts right away cold. To get it started hot, I have to put the idle speed lever way up and let the engine run a while on high idle or else it stalls if I try to put it in gear. When I start it hot or cold, a lot of smoke comes out of the exhaust.
The oil pump gear went a long time ago and I have been using Mercury oil 50:1 premix. I took out the oil pump shaft, but someone said if I didn't take out the bushing it could fall into the engine and raise rim. How does one get the bushing out?
If it sound like a stuck float, where do I get genuine OEM rebuild kits for this outboard? Is there a test to see which carb needs to be rebuilt?
Other than this problem and the oil pump gear, this motor has been very good. I've had some gauges go bad, first the tilt gauge and now the tach quit working, and it looks like the oil warning module is going bad. But the engine itself has been a brute.
