Re: 200 HP. Choke Solenoid
hooty they got a guy selling off some 1979evin 200 stuff on ebay cheaP
SEARCH THE EVINRUDE AND JOHNSON SECTIONS under outboard engine components .i usually switch back to the old ebay . the new setup is not as easy to search ,i will be on there later .see if i can find it for you i think it was a buy it now for 5 dollars ,they also had newer electronics for that motor including ststor/ timerbase /starter /regulator/rectifyer / both packs /and harness for 70 dollars
thanks for that info on the ty straps
later Bennyb
