Thanks again to everyone out there thats offered exellent advise.
1987 omc 2.3, I rebuilt carb, installed new fuel pump, new fuel filter,
cleaned the fuel tank vent as much as i could, pulled the pick-up tube and cleaned, noticed cracked fuel line at both ends and was able to cut off enough to get by the cracks and still re-attach lines. Still no fuel to the filter.
Problem #2 hit the key and the starter engages, however, the solinoid doesen't release and I have to scramble to remove the battery lead. Tried tapping, nothing. The battery I am currently using is not the best,however it produces 13 volts at a full charge. Any help would be appreciated.
Allons
Allons
