rmurray
- Apr 17, 2007
- 125
I did my first gear lube change today and I am a little concerned. I have an alpha 1 outdrive and I properly drained the old oil (both drain screws and fill screws out). I connected a hand pump to the lower fill hole and pumped until the bottle of lube almost emptied and proceeded to pump some air pockets through the pump hose and into the outdrive. While running to the store to get another bottle of gear lube, I left the air vent screw out hoping any air would float to the top and escape (about 20 minutes). Upon returning, I connected the new bottle and continued to fill until the lube reached the appropriate height. Should I be concerned about air being trapped in the outdrive? Thanks!
