I have a 1999 Merc 115 HP. The motor lacks power off idle. Recently I replaced the water cover that had cracked on the rear of the motor. The crack was causing water to spray on the bottom spark plug and was causing a severe missfire. When I replaced the cover I changed the Spark plugs I also checked the compression which was even at about 120psi across the board. After that repair it ran great for a week and then the power loss came back. I checked for spark again and its good. The compression is still good. So Im wondering if anyone has an opinion on the most likely culprit for fuel problems. I think that it is the accelerator pump, If I start the motor I can depress the rod that sticks out of the pump and I get basically no response from the motor until it is fully depressed. Any ideas would be great the Salmon are biting and I need to get back out there.
