SillikerW506
- Aug 8, 2013
- 1
Soo where to start. Had engine hydrolock over the weekend. Immediately took all plugs out turned it over to drain water put plugs in and engine run fine. On Tuesday evening put boat in water and went about 1/4 mile and had alarm come on alarm beeped about every 5 seconds. Engine died for power and shut off. Oil pressure gauge seemed sparatic during this time. Engine wouldnt start until about 25 mins of sitting. Finally got it running went to go again and it shut off again. Suddenly it was hyrdolocked again so once again drained water to get engine running. Engine running again and no water in the oil. Today went about the same distance all in a sudden alarm started going off again and started bogging down and died. Suddenly alot of smoke in engine compartment opened it up and shut off engine. Nothing on fire could not tell where smoke came from. Water manifolds seemed really hot but engine temp was fine. let sit for a while and then finally it started again.. Checked the oil and suddenly there is water in the oil. And to top it off will not shift into gear. Thinking when manifolds got hot they may have melted something in linkage?? Any help on any of the above problems is greatly appreciated.
