I'm pretty sure this is a fuel related issue. Started noticing something fishy a little while back.. if I would idle for a long period of time I would notice a small miss upon take off, other than that the motor would run great. If I idled with the motor trimmed up for a decent amount of time, the rougher the miss would be upon take off. But a perfectly smooth ride other than that. Now the problem seems to have worsened. I don't have to idle nearly as long and the miss is a bit more noticable. But once you get going it's a smooth ride.
I started off checking my fuel flow all the way up to the carbs. My main fuel line is only a year old along with the filter. The fuel pump looked good, no tears on diaphragm or torn gaskets. It appeared my fuel flow to the carbs is fine. I replaced all of my oil lines that run from cylinder to cylinder, they looked a bit rough and noticed a little oil that seemed to be mildly seeping out of two of the lines. Compression is good. 125-130psi on all cylinders. Adequate spark on all cylinders as well. Decided to pull the carbs off and clean them out. Had a little gunk come out of the jets on the middle and bottom carburetors. The floats weren't perfectly level, they were all set about 1/16th of an inch downward (as if the carb were mounted). I made sure they were set exactly the way they were when I put the carbs back together. The needles all seemed to be seating down properly afterwards as well. I pumped the bubble tight after I mounted them back on and nothing was being released. I assumed all should be good to go.
The idling seems to be slightly better now, but still a little bit of a miss during take off after a bit of an idle. The motor will run perfectly fine for a few minutes, then all of the sudden it will lose power for a second or two then pick back up. It will only do this after running approx. 5/8th throttle to WOT for a few minutes. When it loses power, it's not missing at all, just a smooth loss of power. First time it did this, I pulled the cowling off and noticed a milky white liquid all over the middle and bottom carbs. After a while sitting down and not running the motor, it'll just evaporate. I decided to see if it would show up again by only idling for a few minutes. And yes it did. As long as the motor is running for a few minutes, this white milky stuff appears on the bottom two carburetors, while the top one has plain water condensating around it. Yes, sounds like water in my fuel. But I want to learn why it only shows up on my bottom two carbs? Would you think that my motor would run perfectly fine for a few minutes every time before it loses power for a second or so if there was water in my gas? I would think it would cut out immediately as soon as I mash the gas. Maybe I didn't put the carbs back together properly and something is releasing pressure after running for a few minutes? Just wonder if I possibly have more problems than one. What do you think?
I plan on draining my gas tank, cleaning it out, and replacing the vent hose. Other than that, I would like to hear a few suggestions. I have been running ethanol 87 grade fuel as well. I would have to back track a long way to get 100% fuel unfortuantly. Thanks in advance!
