1998 Force 120 (1998 Bayliner) Stiff Steering when in water
bingbong
I took out the boat last weekend, and I encountered an issue with the steering. When turning to the right, the steering wheel spins freely on its own, without touching it. On the other hand, turning left takes A LOT of effort (my wife can't even turn it). This only happens when it is in gear and driving around. When in the garage or in neutral, it seems to be very smooth. Any ideas on how to troubleshoot?
Thanks in advance
foodfisher
Re: 1998 Force 120 (1998 Bayliner) Stiff Steering when in water
Can't remember the correct name of the thing, but under the antiventilation/cavitation plate is an adjustable exhaust snout. Adjust it so that the exhaust is aimed left.
bentle
On 84-94 has what is called the exhaust snout. 95 and up have what is called a trim tab which is what yours has or shout have. It sits just above the prop and is round with a fin pointing downward.. you will need to adjust the steer pulling from there.
bingbong
The trim tab will really make it that hard to turn?
jerryjerry05
Yes.
If it turns hard to the right turn the tab to the right.
bingbong
You were right, trim tab fixed it. I have it turned all the way to the right now, but it works great.
Thanks for your help!
