Hi wondering if anyone can help. Had a problem with my motor stalling very randomly. Would idle fine, then stall on the odd take off, or sometimes @ wot, or mid throttle. Was told it was probably fuel pump. Put a complete kit in the fuel pump and it did the same thing.
It has a portable fuel tank with a primer bulb.
I noticed the primer bulb was soft, and it seemed if I sqeezed it, she'd take off and be normal till the next random stall.
So replaced the fuel filter, inspected the carbs (they look clean), replaced the plugs, replaced the gas tank and fuel line primer bulb. Fresh fuel, proper mix, tightened up the housing bolts for the fuel pump again.
Put the muffs on it tonight and tried it, took a while to get it going, but it only ran for a while then stalled. Had to choke it to start it after it ran and stalled. Seems even worse than before. Argh@$!#%.She seems to run fine when it runs, but then sputters to a complete stall.
Running out of things on the fuel side with exception of pulling carbs.
Electrical now??? Pull the carbs???
Any thoughts/ideas would be much appreciated! Thanks
