I recently purchased a 1998 Tracker boat with a 40HP 2-stroke Tracker (by Mercury) motor on it. I put it in the water and tried to find the location of the water peeing from the motor to determine the condition of the water pump. Although the motor ran good, I was concerned because I couldn't see or hear the tell/tale sign of water peeing from the motor so I shut it off and brought it to the house. After an hour of seaching in the usual places and hooking the motor up to the water hose, I located what appears to be two places located below the fins on the lower unit (below the water line) that appear to be the water outlet. I have a good flow from both and they do not heat up. Is this normal for this motor?
