1997 Johnson 25hp, 2 cyl/2stroke
I bought this motor used last year and it worked fine for a while. However, last summer it started to behave strangely and I can't think of what the cause would be.
When I start it cold, it runs fine. I can go wide open for a while. At some point, however, it starts chugging after a certain RPM level. This RPM level is always the same-- below this threshold it runs perfectly, and above it, it chugs. It's the same RPM level on each outing, too.
By "chug" i mean it seems like it's missing somehow. The motor will jerk around while it's behaving this way. It will consistently behave like this for a while, whether I choke it, turn it off and back on again, etc. After a while (5-30 min) it will stop behaving like this and just work fine again. It's never in-between. It's either 100% perfect or chugging every time i go above that RPM threshold.
I doubt it's anything to do with my carb since it comes on and off randomly. I've tried squeezing the gas bulb while it's doing this and it doesn't seem to have any effect, so I doubt it's having trouble receiving gas. I've also tried running with the cowl off in case it was having trouble getting air, but that didn't have an effect. It may be heat-related since it seems like the only time I can duplicate it is after I've been running it for a while. It's most likely to happen after I've been idling for a few minutes, like waiting in line at a boat landing or something.
Here is a video of it happening. https://www.youtube.com/watch?v=cqRnFO8Onx8
Does anybody have any idea what could be happening? I'm out of ideas and will probably take it to a mechanic, but I'm really nervous about that becuase it only seems to happen intermittently after I've been using it for a while, so I think they'll have trouble duplicating the issue.
